After some more macro pre-processing, I now have a version of zexdoc that my assembler is happy with, so now I can try to narrow down the daa issue.
Curious what you find out. I looked at that thing, and boy, is it opaque.
Hi Will
Here is an example of a test descriptor with macros:
; hl, (38,912 cycles) adc16: db 0c7h ; flag mask tstr <0edh,042h>,0832ch,04f88h,0f22bh,0b339h,07e1fh,01563h,0d3h,089h,0465eh tstr <0,038h>,0,0,0,0f821h,0,0,0,0,0 ; (1024 cycles) tstr 0,0,0,0,-1,-1,-1,0d7h,0,-1 ; (38 cycles) db 0f8h,0b4h,0eah,0a9h ; expected crc tmsg ' hl,' and here is the a test descriptor with macros expanded: ; hl, (38,912 cycles) adc16: db 0c7h ; flag mask db 0edh,042h,0,0 dw 0832ch,04f88h,0f22bh,0b339h,07e1fh,01563h db 0d3h db 089h dw 0465eh db 0,038h,0,0 ; (1024 cycles) dw 0,0,0,0f821h,0,0 db 0 db 0 dw 0 db 0,0,0,0 ; (38 cycles) dw 0,0,0,-1,-1,-1 db 0d7h db 0 dw -1 db 0f8h,0b4h,0eah,0a9h ; expected crc db ' hl,' db '....$'
Yea, thanks, I appreciate that, but I didnāt see (and I didnāt study it in any detail for any length of time) a basic theory of operations. It seems that it takes each group of instructions and somehow iterates through several generations of them, and then CRCs the results they generate. But itās not clear to me how the environment is manifest for each instruction thatās being iterated against.
Hi Will,
There is some info here that I found useful:
http://jeffavery.ca/computers/macintosh_z80exerciser.html
I modified zexdoc to split out the <daa,cpl,scf, and ccf> test into 4 separate tests and I then discovered that daa was not the problem after all. The problem was with the ccf instruction which has a very weird flag side effect. In addition to complementing the C flag, the H flag is set to the old C flag value. After making this change to the Verilog, all of the zexdoc tests are now passing. WooHoo !!
I guess that explains why itās in the same test group as DAA! Very interesting conclusion, thanks for bringing us along.
