Please help me proof-read my multi-dialect reference manual
I’ve just pushed v.1.8.8 of RetroBASIC to GitHub.
Although there are a bunch of changes, the primary one is the addition of a reference manual. I plan on expanding this over time to include more details about different dialects and perhaps even things that I have not implemented (yet!). Perhaps someday it will be the Markdown replacement for The BASIC Handbook?
I’d love to get some feedback on it! It’s in the doc subfolder.
I went to the “doc” subfolder and started reading the only file with the word “manual” in it. I was just starting to settle in and enjoy, but it ended rather abruptly, mid-sentence after only a few hundred words. Did I select the wrong document?
[edit: Ah … I think I found it in the “bas” subfolder …]
Gah! Thanks Xcode!
And thanks to you (using in non-ironically here) for having a look!
Here you go. Hope this helps. It was a nice read and it brought back some memories from when I was messing around with my ZX Spectrum BASIC. :slight_smile:
