On my code I found a section which is obviously data (not detected as such). So I don’t know how/from where these are called.
There are 8 octal values 10, 4, 200, 1000, 40, 100, 20, 400. And 2 words before each. All values are one bit data. 3x 8 bit range, then 1x12 bit. then again. Below is the data in palbart and a bit pattern of the 8 values.
The preceding words are high, maybe 2s complement. Probably no addresses. Almost all 7xxx. 20 has 7000 and 5000.
8x1 bit could be anything. An ASCII character, but would be too much data. I have 8 main instructions on the Festo device. But I assume these are bit patterns for the LCD display. But probably there are LCD driver ICs. I have a dot between display sections. And why this strange order? Any ideas?
addr word
2443 04541 1410 D04541, 1410
2444 04542 7640 SZA CLA
2445 04543 5336 JMP L04536
2446 04544 1410 TAD I P00010
2447 04545 3134 DCA P00134
2448 04546 5020 JMP P00020 code?
2449 04547 7774 SNA SPA SZL CLA OSR --- start? for 10-
2450 04550 7744 SZA SMA CLA OSR
2451 04551 0010 AND P00010 ---------10
2452 04552 7770 SNA SPA SZL CLA
2453 04553 7750 SNA SPA CLA
2454 04554 0004 AND D00004
2455 04555 7777 7777
2456 04556 7740 SZA SMA CLA
2457 04557 0200 AND P04400
2458 04560 7777 7777
2459 04561 7701 7701
2460 04562 1000 TAD S00000
2461 04563 7700 SMA CLA
2462 04564 7700 SMA CLA
2463 04565 0040 AND D00040
2464 04566 7700 SMA CLA
2465 04567 7600 D04567, 7600
2466 04570 0100 AND P00100
2467 04571 7000 NOP
2468 04572 5000 JMP S00000
2469 04573 0020 AND P00020
2470 04574 7700 SMA CLA
2471 04575 7400 7400
2472 04576 0400 AND I S00000 -end ??
2473 04577 0000 AND S00000 -empty?
2474
2475 4600 *4600 ----------new page
2476 04600 0000 D04600, 0000
2477 04601 2000 ISZ S00000
2478 04602 1103 TAD D00103
2479 04603 3054 DCA L00054
2480 04604 1104 TAD D00104
_ _ _X_ _ _ 10 (hex 8)
_ _ _ _X_ _ 4
X_ _ _ _ _ _ 200 (80)
_ _X _ _ _ _ _ _ _ _ _ - 1000 (200 hex, 512 dec)
_ _X_ _ _ _ _ 40 (20) space?
_X_ _ _ _ _ _ 100 (40)
_ _ _X_ _ _ _ 20 (10)
_ _ _X _ _ _ _ _ _ _ _ - 400 (100 hex, 256 dec)
