There are different subroutine techniques including parameters after JMS, multiple return paths, linked lists and software-managed stacks (auto-index). Not sure if all works on the 6100 as well due to different auto-index behaviour.
I think I don’t have any of those. Linked lists don’t have JMS, stacks need manual definitions first. For the rest is no space. On my code I have many JMS, but I haven’t found any returns. Return addresses were written but never called (JMP I). Maybe Intersil has something else. Or the code is constructed in a run as this is on the Zero page.
On my Festo device when importing data (push keys extern, F0 and parameters) there is an output of / + XOn. As the TTY needs ASCII and Xon is not coded in Sixbit, I’ve converted both to octal making 57 and 21 which I found together at 6542, 6543. At code after each value is a JMS 175 subroutine probably for printing. Later is IOF. Elsewhere it’s similar with CR+LF for export. So very plausible. Inside a subroutine, there are loops (due to missing hardware) and further conditional branches and long jumps. So I have to manually skip and change PC or AC.
It’s very hard to keep track of everything due to the overwritten data. Some emulators support extended memory. I could rewrite the code but it’s too much work.
Data is even easier to be detected on a palbart disassembly. Longer data section here
addr word
3482 06540 5024 JMP L00024
3483 06541 2500 D06541, 2500
3484 06542 0057 D06542, 0057 -2F Hex ="/" - used on TAD instr
3485 06543 0021 D06543, 0021 -11 Hex =Xon -TAD
3486 06544 6200 D06544, 6200 -? 3rd value -TAD
3487 06545 7767 D06545, 7767 -TAD
3488 06546 0100 D06546, 0100 - AND instr
3489 06547 0177 P06547, P00177 -DCA
3490 06550 2200 D06550, 2200 -TAD
3491 06551 6700 D06551, 6700 -TAD
3492 06552 4452 D06552, 4452 -TAD
3493 06553 7325 CLA CLL CML RAL IAC
code at 6427:
3409 06427 6402 L06427, 6402 (Skip If Receive Word Count Overflow IOT
3410 06430 0346 AND D06546 -100
3411 06431 7650 SNA CLA
3412 06432 5223 JMP L06423
3413 06433 2134 ISZ P00134 7776 -2, 2 char?
3414 06434 5227 JMP L06427 loop to top
3415 06435 1123 TAD P00123 7560 4+3 digits?
3416 06436 0036 AND P00036 3070
3417 06437 7650 SNA CLA
3418 06440 5245 JMP L06445
3419 06441 4023 JMS P00023 JMS 24 another subroutine
3420 06442 3747 DCA I P06547
3421 06443 1342 TAD D06542 - 57 "/"
3422 06444 4175 JMS P00175 JMS 175+1 print char?
3423 06445 1343 L06445, TAD D06543 - Xon
3424 06446 4175 JMS P00175 print char
3425 06447 1344 TAD D06544 6200
3426 06450 6415 6415 Read Status 1
3427 06451 6002 IOF disable IRQ
3428 06452 1345 TAD D06545 7767 -8
3429 06453 3135 DCA D00135
3430 06454 6407 L06454, 6407
and a run
[6442] IRQ,DLY,IE=0,1,0 L/AC:0/0000 MQ:0000 IR:3747 DCA I @@47 ;Deposit AC to memory then clear AC, Indexed Current page @@47
[6443] IRQ,DLY,IE=0,1,0 L/AC:0/0000 MQ:0000 IR:1342 TAD @@42 ;Add operand to AC, Current page @@42
[6444] IRQ,DLY,IE=0,1,0 L/AC:0/0057 MQ:0000 IR:4175 JMS 0175 ;Jump to subroutine ZP 0175
[0176] IRQ,DLY,IE=0,0,0 L/AC:0/0057 MQ:0000 IR:2140 ISZ 0140 ;Increment operand and skip if zero, ZP 0140
[0177] IRQ,DLY,IE=0,0,0 L/AC:0/0057 MQ:0000 IR:0000 AND 0000 ;AND operand with AC, ZP 0000
[0200] IRQ,DLY,IE=0,0,0 L/AC:0/0044 MQ:0000 IR:1014 TAD 0014 ;Add operand to AC, ZP 0014
[0201] IRQ,DLY,IE=0,0,0 L/AC:0/1366 MQ:0000 IR:0211 AND @@11 ;AND operand with AC, Current page @@11
[0202] IRQ,DLY,IE=0,0,0 L/AC:0/1000 MQ:0000 IR:7450 SNA ;Skip on AC <> 0
[0204] IRQ,DLY,IE=0,0,0 L/AC:0/1000 MQ:0000 IR:7041 CIA ;2s Complement AC
[0205] IRQ,DLY,IE=0,0,0 L/AC:0/7000 MQ:0000 IR:1130 TAD 0130 ;Add operand to AC, ZP 0130
[0206] IRQ,DLY,IE=0,0,0 L/AC:1/3760 MQ:0000 IR:7640 SZA CLA ;Skip on AC = 0, Clear AC
[0207] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:5233 JMP @@33 ;Jump Current page @@33
[0233] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:1072 TAD 0072 ;Add operand to AC, ZP 0072
[0234] IRQ,DLY,IE=0,0,0 L/AC:1/1126 MQ:0000 IR:7002 BSW ;Byte Swap AC
[0235] IRQ,DLY,IE=0,0,0 L/AC:1/2611 MQ:0000 IR:7700 SMA CLA ;Skip on AC < 0, Clear AC
[0236] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:5431 JMP I 0031 ;Jump Indexed ZP 0031
[1313] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:5366 JMP @@66 ;Jump Current page @@66
[1366] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:6223 CDF 2 CIF 2;KM8-E: Change to Data and Instruction Field 2
[1367] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:7325 STL CLA IAC RAL;Set L, Set AC to 0001, Rotate AC & L left
[1370] IRQ,DLY,IE=0,0,0 L/AC:0/0003 MQ:0000 IR:0132 AND 0132 ;AND operand with AC, ZP 0132
[1371] IRQ,DLY,IE=0,0,0 L/AC:0/0001 MQ:0000 IR:3101 DCA 0101 ;Deposit AC to memory then clear AC, ZP 0101
[1372] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1133 TAD 0133 ;Add operand to AC, ZP 0133
[1373] IRQ,DLY,IE=0,0,0 L/AC:0/6753 MQ:0000 IR:3102 DCA 0102 ;Deposit AC to memory then clear AC, ZP 0102
[1374] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:5750 JMP I @@50 ;Jump Indexed Current page @@50
[5330] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1373 TAD @@73 ;Add operand to AC, Current page @@73
same on ROM 5162, 2nd half first. Same data/relative addresses, but different Zero page
[2442] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:3747 DCA I @@47 ;Deposit AC to memory then clear AC, Indexed Current page @@47
[2443] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1342 TAD @@42 ;Add operand to AC, Current page @@42
[2444] IRQ,DLY,IE=0,0,0 L/AC:0/0057 MQ:0000 IR:4175 JMS 0175 ;Jump to subroutine ZP 0175
[0176] IRQ,DLY,IE=0,0,0 L/AC:0/0057 MQ:0000 IR:3061 DCA 0061 ;Deposit AC to memory then clear AC, ZP 0061
[0177] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:0000 AND 0000 ;AND operand with AC, ZP 0000
[0200] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1263 TAD @@63 ;Add operand to AC, Current page @@63
[0201] IRQ,DLY,IE=0,0,0 L/AC:0/0164 MQ:0000 IR:3011 DCA 0011 ;Deposit AC to memory then clear AC, ZP 0011
[0202] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7307 CLL CLA IAC RTL;Clear L, Set AC to 0001, Rotate AC & L left twice
[0203] IRQ,DLY,IE=0,0,0 L/AC:0/0004 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0204] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7303 CLL CLA IAC BSW;Clear L, set AC to 0100
[0205] IRQ,DLY,IE=0,0,0 L/AC:0/0100 MQ:0000 IR:1116 TAD 0116 ;Add operand to AC, ZP 0116
[0206] IRQ,DLY,IE=0,0,0 L/AC:1/0072 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0207] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:1101 TAD 0101 ;Add operand to AC, ZP 0101
[0210] IRQ,DLY,IE=0,0,0 L/AC:1/3104 MQ:0000 IR:7650 SNA CLA ;Skip on AC <> 0, Clear AC
[0212] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:1266 TAD @@66 ;Add operand to AC, Current page @@66
[0213] IRQ,DLY,IE=0,0,0 L/AC:1/0005 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0214] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:1265 TAD @@65 ;Add operand to AC, Current page @@65
[0215] IRQ,DLY,IE=0,0,0 L/AC:1/0400 MQ:0000 IR:1101 TAD 0101 ;Add operand to AC, ZP 0101
[0216] IRQ,DLY,IE=0,0,0 L/AC:1/3504 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0217] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:7327 STL CLA IAC RTL;Set L, Set AC to 0001, Rotate AC & L left twice
[0220] IRQ,DLY,IE=0,0,0 L/AC:0/0006 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0221] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1102 TAD 0102 ;Add operand to AC, ZP 0102
[0222] IRQ,DLY,IE=0,0,0 L/AC:0/5423 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0223] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7330 STL CLA RAR;Set L, Move L into AC bit 0
[0224] IRQ,DLY,IE=0,0,0 L/AC:0/4000 MQ:0000 IR:3411 DCA I 0011 ;Deposit AC to memory then clear AC, Indexed ZP 0011 [Auto pre-inc]
[0225] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1263 TAD @@63 ;Add operand to AC, Current page @@63
[0226] IRQ,DLY,IE=0,0,0 L/AC:0/0164 MQ:0000 IR:3016 DCA 0016 ;Deposit AC to memory then clear AC, ZP 0016
[0227] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7307 CLL CLA IAC RTL;Clear L, Set AC to 0001, Rotate AC & L left twice
[0230] IRQ,DLY,IE=0,0,0 L/AC:0/0004 MQ:0000 IR:6436 SSBE ;DP8-EAEB: Skip on Bus Error
[0231] IRQ,DLY,IE=0,0,0 L/AC:0/0004 MQ:0000 IR:6406 SCSD ;DP8-EAEB: Clear Sync Detect
[0232] IRQ,DLY,IE=0,0,0 L/AC:0/0004 MQ:0000 IR:0235 AND @@35 ;AND operand with AC, Current page @@35
[0233] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:6437 SRCD ;DP8-EAEB: Read Character Detected
[0234] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:4017 JMS 0017 ;Jump to subroutine ZP 0017
[0020] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1107 TAD 0107 ;Add operand to AC, ZP 0107
