I found an 6100 Assembler called PALX here. In folder ossmb is a bin, pa and lst file. The PAL.EXE works (runs under Win32/64 bit but needs 32 bit Cygwin (2 dll files). PALX is also on the SBC6120 tools.
Assembling works but starts/moves addr 0 to 200 and quits at 7647 (real 7407) as the symbol table is full, relative addresses remain. Although an error it has 2 passes and outputs a bin file (what is different/incomplete). At least I know the behavior of the 6100 RTL/RTR instructions and have some commented sources.
Very interesting also the SMAL8 assembler there. Here is a text shown. Obviously same file in PALX not showing text. Not sure why. 1720->5760, so +4040 (A=01 /41), so I have to substract 40. (But only for text). I wrote a c script including printf(“%c”, temp+32); (instead of temp+64) resulting in an interesting ASCII file. None of my missing mnemonics but some pattern with underlines, could be an output for LCD or printer. But maybe just a bug in converting SIXBIT. I also now see the text alignment. Not backwards or just the right half of the word (vertically like usual eg. in CHEKMO).
ossmb.bin doesn’t work maybe due to missing external input devices (I haven’t checked all emulators).
Palbart and Macro8 (not 6100 specific) also showing symbol table and cross ref list. ossmb/PALX also a memory list.
Some early assemblers (mainly running under PDP-8) should also handle 6100 like PAL-II but probably that is a spelling error and is in fact PAL-III. Another Win Cross assembler with 6100 support is Macro Assembler {AS} V1.42 (‘‘ACASM’’).
SMAL8 assembler SMAL8.EXE ->.o ->o2bin ->online emu to dump this listing
02011 4263 "2 | a2011, JMS C2063 <- JMS TERR
02012 1720 OP | a2012, TAD I M2120 <- SIXBIT text: Open Failed
02013 0516 EN | a2013, AND I M116
02014 4006 F | a2014, JMS C6
02015 0111 AI | a2015, AND M111
02016 1405 LE | a2016, TAD I M5
02017 0400 D@ | a2017, AND I M0 <- @ end text
02020 4773 `: | a2020, JMS I C2173
PALX 6100 compiler PALX - IM6100/HM6120 Assembly Language V3.32 RLA 08-MAR-12 PALX.EXE
02012 5760 ./ | a2012, JMP I J2160 <- NOT SIXBIT
02013 4556 %. | a2013, JMS I C156
02014 0046 @& | a2014, AND M46
02015 4151 !) | a2015, JMS C151
02016 5445 ,% | a2016, JMP I J45
02017 4400 $@ | a2017, JMS I C0
ossmba.pa (PAL)
CLERR: JMS TERR ; Close failure
.SIXBIT /CLOSE FAILED/
ossmb.lsr (note 12007=2007)
341 12007 7700 SMA CLA ; Error. If AC < 0, it was fatal
342 12010 5220 JMP OK ; Non file structured output
343 12011 4263 JMS TERR
344 12012 .SIXBIT /OPEN FAILED/
345 12020 4773 OK: JMS @[ICHAR] ; Read a character
