I’ve spent a fair amount of time tracking down oddball dialects of BASIC and one bit I’ve still never nailed down for sure:
What was the first BASIC dialect to use the MID/LEFT/RIGHT syntax for string manipulation?
Dartmouth didn’t get any form of string manipulation until Version The Fourth of (early) 1968 and this used the CHANGE command. Some variation on this theme was used in most mainframe dialects.
HP BASIC from the 2000 series appears to be the first to use slicing, although they blew it and used the identical syntax as array accessing and thus made it impossible to have a string array. Many later micro versions failed to address this problem (I’m looking at you Apple and Atari). This was addressed in Sinclair’s dialect (using “A TO B”) and in Full/ANSI BASIC (using “A:B”).
I’ve long thought MID/LEFT/RIGHT came from DEC when they finally ditched FOCAL on their larger systems. But from what I understand, their first dialect with this feature is from around 1970? Does anyone know for sure?
I also know that Tymshare’s SUPER BASIC included these, and I believed they were the first. These date to late 1968.
What has thrown all of this into confusion is when I came across the manual for TENET BASIC from July 1970 on the TENET 210 (which was built to the extent of a single example). This also uses MID/LEFT/RIGHT, and as literally everything about this machine is deliberately derivative of some other platform, this really implies that there is some dialect earlier than 1970 that used this.
Can anyone here point to a dialect of BASIC that used this syntax prior to ~1968?
The OS/8 team at DEC certainly hadn’t got the memo about LEFT/MID/RIGHT. BASIC for OS/8 has the unusual SEG$() function:
SEG$(X$,Y,Z) Returns the sequence of characters in a string (X$) between two positions in the
string (X,Y)
Example: 30 LET R$=SEG$(“ABCDEF”,2,4)
will assign R$ a value of BCD
OS/8 came later (1972?), though
I was hoping that one of the time-sharing systems (such as Service Bureau Corp’s (= IBM, in weak disguise) CALL/360:BASIC) might’ve introduced the syntax you’re looking for, but so far I’m drawing a blank too.
which BASIC dialect was influential enough to spread this. (The TENET 210 doesn’t look like it
Indeed, and I would think the same is true for Tymshare. DEC, yes, but how would they even know of SUPER-BASIC, as opposed to, say, HP’s array slicing?
But even while writing this… there is every possibility that BASIC-PLUS was written by someone from Tymshare, or someone who wrote it for Tymshare.
I think I need to figure out who the original authors of BASIC-PLUS might have been.
