Tandberg also have the same key but not in black. There’s a symbol of 3 vertical lines striked by an arrow down. From the terminal wiki (Tandberg 2200) I haven’t read the manual. But probably it’s a different key.
https://terminals-wiki.org/wiki/index.php/Tandberg_TDV_2200
Another interesting key is “HERE IS” like on typewriter TI Silent 700 also some maths symbols
Regarding the curved arrows: the German section reads (the same as the English section),
to the position of the preceding character (SML);
with SHIFT-key to the position of the preceding word.to the position of the next character (SMR);
with SHIFT-key to the position of the next word.
Not sure, what SML and SMR are, there is not notion of these anywhere else, but home is SBA, start of a line is SZA, cursor up is SMO, cursor down is SMU.
I would infer that these are movement codes used in SINIX documentation for editing (like for vi, etc), where S may be for “Sondertaste” (special key) or “Sonderfunktion” (special function), M seems to be for motion, Z for “Zeile” (line), and B for “Bild” (screen image), followed by a German abbreviation for the direction.
SBA: S-Bild-Anfang (screen start)
SZA: S-Zeile-Anfang (line start)
SMO: S-Move-Oben (move up)
SMU: S-Move-Unten (move down)
SML: S-Move-Links (move left)
SMR: S-Move-Rechts (move right)
Edit: “M” may be also for “Marke” (cursor), avoiding this English/German mix.
Intertestingly, “Bildende” (end of screen), page up and page down, and end of line don’t have such a code. (These should be SBE, SBO, SBU, and SZE, respectively.)
An interesting key is also “Endmarke” (end marker; function application-dependent) – this seems to be a second function or contextual function of the CTRL key:
This key with three horizontal lines and an arrow, if I had to guess, I’d say a form feed (aka vertical tab).
DIN 2137-1976 (for computer keyboards) may be interesting in context, but I wasn’t able to find a free copy. Moreover, it’s superceded by newer editions (2012, 2018, re-edited 2020), which doesn’t help finding the original 1976 edition.
I wonder, why not even an old DIN standard is available online, but we’ll find out. Must be in some books. (There are also related DIN standards like DIN 2139/07.76 , 2127/07.76 and maybe E DIN 42115, Teil 4. Later DIN/EN standards are for completely different subjects.
The three horizontal lines and arrow seems also rare. I haven’t found it on most Tandberg /Norsk Data keyboard and not in manuals (most are for 2215). But it’s included as character in the ROM.
I found three vertical arrows pointing up (and down) on this Siemens 6.600 keyboard, also 2 horizontal lines with arrow (top middle)
I have the manual. The 3 arrows meaning that the complete text will be moved in that direction (deleting top or bottom line). Maybe the same as the Tandberg key.
Probably these are special commands depending on the hardware and especially software. Maybe we should check the software.
I found also following commands (maybe the arrows were later replaced by text)
EOT Erase Line
EL Erase in Line
EM Erase Page (maybe same as CLR)
ED Erase in display
CBT Cursor backwards tabulation
This is no coincidence. Tandberg was (is?) an OEM supplier for Siemens Transdata Terminals.
Yes, but I mean the 2 specific keys.
I also wonder about the black keyboard. I found very few companies with those Siemens keyboard in black.
One is NCR (I found on commons titled NEC H0150…), and one is Taylorix (who made Triumph-Adler clones).
I have checked many computers and typewriters but I haven’t found any key like that. And I doubt that the DIN would help.
Some days ago the device has been sold. (65 EUR, 5 bids) sold as defective.
As someone can’t do much with it, it’s likely that a (German) museum’s owner bought it and publish it somewhere. Or maybe resell it.
If this refers to the one in very first post, I think this may be a terminal based on international standards – you were mentioning possible Japanese origins – that has been modified for German use. (Mind that this is not QWERTZ, as it would have been if this had been specifically designed for the German region. This is really an interesting mix of layouts.)
The peculiar lack of any markings suggest to me that this had been sourced for a very special purpose, like a one-of-a-kind system or an application that didn’t enjoy much of an exposure (like maintenance/processing tasks integrated with and restricted to a single company, or similar). If this had been the user facing part of a text processing system or had been meant for clerical work, I’d expect to see some proud manufacturer sticker on the front and at least some markings on the back.
(This makes me think that this had either been assembled from distinct parts for a special purpose, or that what we’re seeing here is not the original packaging.)
Those two are distinct. Form feed is 12 and vertical tab is 11 (decimal).
I too guess it’s a Japanese device (designed for the international market), based on the shape of the key caps. I owned a fascinatingly complex Japanese Japanese keyboard before I had to clean my attic. No wonder fax machines became dominant there. I speculate that the | |\| key is “delete”.
I agree what mc4004 and NoLand said.
Although of Japanese origin (and maybe quite wide spread), it’s probably nothing successful/notable.
But still interesting and rare.
I found this site with keyboard photos and characters. The only similar key (of the Tandberg keyboard) is ⇟ (Apple page down) and the Apple Home character ⤒
http://xahlee.info/kbd/keyboard_keys_index.html
http://xahlee.info/comp/unicode_computing_symbols.html
The key on the Tandberg keyboard simply meant “Move five lines downward”.
Edit: I have that keyboard and a couple other variants. If there are other mysterious keys there I can look it up - I have docu for the applications which make use of those special Tandberg keys.
I found this interesting key(s) on a Siemens Simatic 5, looking like a flower. It’s for a hardcopy. There are also keys with 3 horizontal lines and an arrow (Insert segment) and one thick vertical line with 2 diagonal lines (interrupt) and others. These are the upper oval keys, symbols are not printed on the keys but above.
Taken from photos on commons.
The buyer of the original unknown machine has still not given a feedback, what is quite unusual (in Germany). Maybe there are issues. But it’s also not re-offered or offered elsewhere.
During research for my unknown line code, I first found in a mag tape reference manual with BCD code the Triple Plus sign ⧻, but it’s already mentioned.
Now I found on Wikipedia in Fieldata this control key
≢Spare, SOD (graphical in COMLOGNET variant)
SOC=Start of Control Block
SOB= Start of Block
SOD= (not found)
Triple Bar (striked) Unicode U+2263 not identical to
But bars are not vertical. And even when turned at 90 degrees the diagonal line is wrong.
This is ␥ delete U+2425
And this ⎚ is clear screen U+239A
This is both ⩩.
A Japanese character ⾎
So still a mystery
BTW, my favorite key is this one (top right),
I call it the “angry key”. As it happens, just to the left and below is a key reading “ÅNGRA”, but this is rather disappointingly just “undo”. However, immediately to the left, there’s “JUST” – and if this works as a modifier, we may engage in just anger. ![]()
“Ångra” is Swedish for “regret”, which sounds like a good reason for “Undo” ![]()
The “angry face” key is a custom word-processing key for “NOTIS”, used for “center”/“expand” of the current line (I think).
I really, really, miss Norsk Data…
