Sprites mods has done it again.¹ This time, it’s a tiny but operational PDP-11. Case modeled on a VT-102, but it’s really more like a approximately ⅙ scale VT-103 with LSI-11 installed. It runs BSD 2.11 and is networked. He had to get a bit creative to make a 4x10 pixel font readable (with magnification, at least for some of us) on a display that would fit this scale.
This may be the first operational PDP11 with WiFi and Bluetooth.
It is worth reading the whole thing. You’ll see the original tetris, the PDP11 connecting to wifi from a terminal prompt, and then a telnet login over the network.
This may be the first time the original Tetris was played using a bluetooth gamepad?
Skip to the end! Skip to the end!
The giant can cover the entire screen with his thumb!
¹ While Joeren has done a lot of cool hacks, the previous retrocomputing hack was his Miniature Macintosh Plus; a working Mac Plus at a similar scale.
