RTM/Z80 is a multitasking kernel, built for Z80 based computers, written in Z80 assembly language, providing its users with an Application Programming Interface (API) accessible from programs written in the C language and the Z80 assembly language.
It is intended to be a simple and easy to use learning tool, for those who want to understand the tips and tricks of the multitasking software systems.
RTM/Z80 is a “low profile” multitasking system; it is written entirely in Z80 assembler language and uses as a building platform the vintage HiTech Z80 software, which may be run on a “real” Z80 computer or on a Z80 “simulator”. However, you can use also the C language and “mix” C code with Z80 assembly code when writing RTM/Z80 applications.
I just published on GitHub ( GitHub - Laci1953/RTM-Z80: Retro Tiny Multitasking system for Z80 based computers ) my RTM/Z80 project.
I finished the testing on Z80SIM and RC2014 (SC108 and Memory Module).
I’m waiting for your opinions and suggestions!
Ladislau
Welcome - an interesting project!
(I’m trying to build z80sim on my macbook so I can give this a go, but I see there are Windows downloads available:
Z80pack - Zilog Z80 and Intel 8080 Emulator and Crossassembler for UNIX and…
Hi Ed,
you will need to install an Unix-like system on Windows (I used Cygwin) and install there the Z80pack.
For Mac, I do not know…
regards,
Ladislau
I think I got somewhere:
ed$ ../z80sim
Release 1.37, Copyright (C) 1987-2021 by Udo Munk
CPU speed is unlimited, CPU executes undocumented instructions
r filename[,address] read object into memory
d [address] dump memory
l [address] list memory
m [address] modify memory
f address,count,value fill memory
v from,to,count move memory
p address show/modify port
g [address] run program
t [count] trace program
return single step program
x [register] show/modify register
x f<flag> modify flag
b[no] address[,pass] set soft breakpoint
b show soft breakpoints
b[no] c clear soft breakpoint
h [address] show history
h c clear history
z start,stop set trigger adr for t-state count
z show t-state count
c measure clock frequency
s show settings
! command execute UNIX command
q quit
I’ll be busy for a couple of days, but perhaps this is a start. I realise this is just getting together the substrate on which to run your RTM.
Hi,
yes, you are on the right track…
However, you must add on top of Z80SIM the CPMSIM pack; to start-it, see below:
ladis@DESKTOP-8BT3O9R ~
$ ls
z80pack-1.36 z80pack-1.36.tgz
$ cd z80pack-1.36
ladis@DESKTOP-8BT3O9R ~/z80pack-1…36
$ cd cpmsim
ladis@DESKTOP-8BT3O9R ~/z80pack-1.36/cpmsim
$ ./cpm2
Release 1.36, Copyright (C) 1987-2017 by Udo Munk
Booting…
64K CP/M Vers. 2.2 (Z80 CBIOS V1.2 for Z80SIM, Copyright 1988-2007 by Udo Munk)
A>
I managed to put all my tools & source files on the 4MB disk; I’ve used J> , but also I> is an option.
You may find the HiTech tools at: Z80pack - Zilog Z80 and Intel 8080 Emulator and Crossassembler for UNIX and Windows , just search ‘Hitech’ on this page and download the disk.
regards,
Ladislau
Hi EdS,
here is a little movie showing the demo in action:
https://twitter.com/i/status/1429817669847552001
Ladislau
Nice, thanks! As you might guess, I haven’t quite got back to picking up the thread of what I was doing…
