For various reasons, I’ve been researching the Ramo-Wooldridge RW-300 digital control computer, announced in July 1957 and first operated in March 1959 in closed-loop operation at a Texaco oil refinery. (In 1958, Ramo-Wooldridge merged with Thompson Products to become Thompson Ramo Wooldridge Inc., better known as TRW.)
This was essentially the first digital computer targeted specifically at industrial process control, with an integrated analog-to-digital and digital-to-analog converter module. TRW’s marketing savvy hit a sweet spot with the RW-300, and it was installed in dozens of industrial facilities by 1963: cement kilns, oil refineries, petrochemical plants, electric power stations, nuclear reactors, air traffic control, etc.
Thankfully, there is an amazing amount of freely-available technical information online about this pioneering computer (see references below), which I’ve been reading eagerly. The RW-300 architecture was based on an 18-bit word and seems to be centered around a magnetic drum memory (7936 words base, 15360 words with “expanded drum” option “for a slight extra charge”). There doesn’t seem to be a “clock rate” per se, but rather the instruction cycle time (“word time” in the manuals) is related to the sector rate of the drum memory = 60 Hz / 128 sectors = 130.2 microseconds (7680 Hz), with addition taking 6 or 7 cycles, multiplication 23 cycles, and division 24 cycles. Digital computation used diode-transistor logic; the exact number of semiconductor components is unclear but seems to be about 4000 diodes and 500 transistors (TRW source documentation says exactly “460 transistors in the computer proper.”) Analog-to-digital and digital-to-analog conversion were independent from the processor, essentially “mapping” tracks on the drum to ADC inputs and DAC outputs. The RW-300 included a watchdog timer — so both the concept and the term dates back to at least the late 1950s.
This computer was about the size of a desk, with a power consumption of about 500 watts. Cost was $98,000 for the base unit (digital only); the US National Aviation Facilities Experimental Station in Atlantic City, NJ purchased an RW-300 for about $304,000 including a reasonable set of optional modules: ADC/DAC converter module, 64-channel ADC input multiplexer, 36-channel DAC output mux and sample-and-hold, 504 digital outputs, 288 digital inputs, 4 magnetic tape units, real-time clock. (In 2025 dollars these costs would be $1.08M and $3.36M.)
I wonder what they did to run this computer internationally in places where the line frequency was 50 Hz, since the drum motor was synchronous and therefore would have run at the line frequency provided. (“My colleagues in the United States have 20% higher computing performance than we do, with the same hardware! It’s not fair!”)
References:
- Computer History Museum, Computers in Control
- Bitsavers TRW RW-300
- Kennett Classic Computer Museum Library
- Martin H. Weik, A third survey of domestic electronic digital computing systems, Ballistic Research Laboratory Report 1115, March 1961
- W. E. Frady and M. Phister, System characteristics of a computer controller for use in the process industries, Dec 1957
- H. F. Kloch and J. D. Schoeffler, Direct Digital Control at the Threshold, Electronics, March 23 1964
- New Digital Computer for Process Control, Control Engineering, September 1957
[Cross-posted to https://www.reddit.com/r/ECE/comments/1lc68kf/the_ramowooldridge_rw300_historical/]
[Edit: add link to Kennett Classic]
