Thanks, found it. I can fine tune those, I can see some further optimizations. A likely route is to handle signed and unsigned compares separately, that can be done.
Question for you: I would like to log a gcc defect for this, can I credit you for the report? Along the same lines, I’d credit you for contributing to the solution, unless you’d prefer not to be mentioned.
Yes, I’d be happy to be credited in this way.
You show up with an alias “hoglet” here, but the email notification seems to have a real name. Which name should I use?
Also: can I use your spigot program as a test case for the GCC test suite to use?
I tend to use both: David Banks (hoglet)
Please go ahead and use the Pi Spigot as a test case.
Dave
In the current development stream compiler (V13.0) the divide at line 93 (“p /= 10;”) generates a div instruction rather than a library call to unsigned 16 bit divide. The “unsigned” bit makes no sense, the current code does a signed divide as it should.
The long divides do generate library calls, as they must since they produce 32 bit quotients which isn’t what “div” does.
The register issue is still there, in -O0 only.
These changes were originally against the GCC 11.2 source tree, whch I think was the latest stable release the time.
This was the command I was using to build:
pdp11-aout-gcc -nostdlib -Ttext $ADDR src/crt0_gcc.s src/$i -lgcc -o $name
As far as I recall, I was working without optimization because there were more issues when optimization was enabled.
I’m not sure I’m following here; line 93 of which file?
spigot.c line 93, in function “print”.
In the version I built 4 months ago, that particular division in print() also generated a DIV instruction.
We are possibly talking at cross-purposes here.
Are you saying that one or other of the patches either is no longer needed, or just plain doesn’t make sense?
I have the latest GCC sources (from the git mirror) now checked out, so I’m able to fairly quickly test things.
It seems only the second patch (to pdp11.md) is needed for the spigot test case to run.
Here’s my test case for the first patch:
#include "tube.h"
void outhex(uint8_t i);
void outhex32(uint32_t i);
void outnl();
int program() {
uint32_t a = 0x12345678;
uint32_t *ap = &a;
outhex32(*ap);
outnl();
void outhex(uint8_t i) {
i &= 15;
if (i > 9) {
outc(i + ('A' - 10));
} else {
outc(i + '0');
void outhex32(uint32_t i) {
int d;
for (d = 0; d < 8; d++) {
// Note: this uses ASHC which is a signed shift
outhex((uint8_t)(i >> 28));
i <<= 4;
void outnl() {
outc(10);
outc(13);
This fails with the latest GCC, which generates the following code:
00000128 <_program>:
128: 1166 mov r5, -(sp)
12a: 1185 mov sp, r5
12c: 65c6 fffa add $-6, sp
130: 15f5 1234 fffa mov $11064, -6(r5)
136: 15f5 5678 fffc mov $53170, -4(r5)
13c: 15c0 fffa mov $-6, r0
140: 6140 add r5, r0
142: 1035 fffe mov r0, -2(r5)
146: 1d40 fffe mov -2(r5), r0
14a: 1200 mov (r0), r0 <<<<< clobbers r0
14c: 1c01 0002 mov 2(r0), r1
150: 1066 mov r1, -(sp)
152: 1026 mov r0, -(sp)
154: 09f7 004e jsr pc, 1a6 <_outhex32>
158: 65c6 0004 add $4, sp
15c: 09f7 009c jsr pc, 1fc <_outnl>
160: 00a0 nop
162: 1146 mov r5, sp
164: 1585 mov (sp)+, r5
166: 0087 rts pc
With the patch (to pdp11.cc), the code is:
14a: 1c01 0002 mov 2(r0), r1 <<<< swapped
14e: 1200 mov (r0), r0 <<<< swapped
160: 00a0 nop
166: 0087 rts pc
This is all with -O0
When we finally get our Imp77 compilers resurrected fully, remind me to build the old Pdp11
Imp compiler for you. It did rather well in Brian Wichmann’s Ackermann benchmark*, a little more info on which is mentioned here - we should have the ability to generate pdp11 assembler text interspersed with Imp source text so you can compare it to GCC et al. Due to some limitations in the current compilers, the pdp11 compiler isn’t ready to be rebuilt, but an older version of the source with some bits not yet recreated is temporarily at https://gtoal.com/tmp/imp11/ if you like looking at that sort of thing (ie unfamiliar languages, compiler code, historical software, etc).
[*: https://history.dcs.ed.ac.uk/archive/docs/Imp_Benchmarks/acklt.pdf
https://history.dcs.ed.ac.uk/archive/docs/Imp_Benchmarks/ackpe.pdf
https://history.dcs.ed.ac.uk/archive/docs/Imp_Benchmarks/ack.pdf ]
Excellent articles! Recommended reading for lovers of the older architectures.
Ritchie’s C compiler can be tryed too - bkunix/cross-devel at master · sergev/bkunix · GitHub
Nice find! From the README in that repo:
After learning about the existence of Mini-Unix and LSX — the minimalistic Unix kernels derived from Unix V6 — and reviving the latter from an incomplete floppy image dump, I realized that it could have been possible to run a real Unix on BK-0010. Indeed, LSX in its minimal configuration required only 40 KB of RAM, and a BK with a floppy controller could provide up to 44 KB.
As all the LSX and Mini-Unix sources were written in an ancient dialect of the C language (no
unsigned,void,long; weird — by today’s standards — syntax of assignment operators and initializations), the first step was to patch the source to conform to the newer style of C.An initial attempt to use GCC for cross-development failed: it produced a buggy and size-inefficient code. We have settled on using the Ritchie C compiler from a BSD distribution and the Johnson Portable C compiler (PCC). In the process, quite a few bugs in PCC got fixed.
Is that the original PCC or a newer version?
The program compiles fine using the C compiler on 2.11BSD. I’m using the 2.11BSD disk image from here, running it on top of OpenSIMH.
That compiler also works under Apout – I was using it a few days ago!
Cheers, Warren
Oh, now that’s rather a splendid thing!
… a user-level simulator for UNIX a.out binaries. Binaries for V1, V2, V5, V6, V7, 2.9BSD and 2.11BSD can be run with this simulator. The user-mode PDP-11 instructions are simulated, and TRAP instructions are emulated by calling equivalent native-mode system calls.
I believe there is a DECUS C compiler that runs under RSX11.
I am running RSX (OK, something close to it) on my DEC Pro 350. I am very interested in the DECUS C compiler for RSX11. Does anyone have experience with it?
Johnny Billquist et al have been discussing it on Discord recently. I’m not sure it was DECUS C, but at least some sort of C compiler on RSX11.
I compiled this program with the RSX11M C compiler from Johnny Billquist’s RSX11M-PLUS RPM repository. This says it is a DEC compiler (Information about C). Initially the program crashed but I guessed it had run out of stack space so I changed the variables to static. It then ran successfully but it took a long time as I’m running SIMH on a Raspberry Pi 2B.
