I am missing a power supply and am looking for advice / pointers as to how to build a replacement. It outputs +12v -12v +5v at around 80W.
Not sure where to start… I’ve seen metalboxed PSUs with tabs for AC in, DC out online. But I need a C13 style plug also I guess so I’d need another box to mount that (?)
Does it need to have the same physical dimensions? You can easily buy standard PC power supplies - and those output the voltages you want and come with a metal case and an IEC mains input socket. They’re Likely to have a higher capacity than 80W, but that shouldn’t matter, unless they’re physically too big.
You can search for ATX power supply. If you want to get from the standard multi-pin ATX connector to screw terminals, there are lots of cheap adapter boards available - search for “ATX power adapter board” - some of those even have LED displays built in to monitor the supplied voltages.
Regarding the ‘trickle circuitry’: yes, the more modern supplies do have that, but it’s easy to wire a momentary contact push button to link two of the wires for ‘start’. You can also permanently connect them together if you don’t need the on/standby functionality.
It’s 15cm x 8cm x 4cm. That one is rated 220V AC input: you might need to search for something similar if you need 115V AC input - I don’t know if that one would work on the lower input voltage, though some of them work on both supply voltages without having to set any switches.
I’d second using a MeanWell PSU … However … Last time I tried to buy one in the UK I had to prove that I was a bona-fide business to Mouser and Meanwell directly themselves.
I’ve no idea why … I am a bona-fide business in the UK, in the capacity as “sole trader”. This is recognised by HMRC, but not MeanWell, nor mouser.
This PSU also taps out 220 AC to the display (see photo). The circuit diagram shows the tap coming after the suppression Caps and an inductor. I’m guessing I can find some place in these meanwell PSUs to do the same. (?)
Given the display PSU has X/Y caps anyway, perhaps just feeding 220VAC after the power SPDT switch would work too.
I don’t know what I’m talking about, when it comes to PSUs, but I see the PicoPSU used for restoration projects. These are tiny circuitboards that take 12V DC input and deliver voltages in configurations for various retro computers.
(Notably, you’d have to find a separate solution for the 220V tab.)
Cheers, This workstation needs around 100W from the PSU - but yes something like this.
I haven’t figured out how I’m going to generate the Display supply yet. I think it needs a tap from the 220VAC but also looks like it needs 70VAC (iff I’m reading the schematics right - which is a big if).
I’m also going to have to 3d print a case. All Tektronix equipment seem to have a penchant for having a really long plastic rod from the front panel power button to a latching power switch - so building something that holds the switch at the right angle to join up with the long plastic rod will be fun.
Had to smile as I recollected one of my very earliest tasks as an electrical apprentice - basically take this sheet of metal, these 50-60 “E” pieces of iron, these reels of wire, and make, yes make, a power supply transformer for an amplifier that “you will build” during next year as part of workshop practices training (RAF Locking, 1959), still have it lurking in collected scrap box. Of course the sensible answer(s) have been given by others, and impromptu answer would have been " find a scrap Desk-top computer where similar V’s were common " and lift the PSU from that - most have labels telling you wattage, current available. The intended target looked as though it had a cathode ray tube for the screen - which would need a EHT supply -not part of standard 12/12/5 PSUs but a simple standard cct - often driven by the line oscillator itself fed by the PSU - probably part of the display board tho cased for safety. In any case personal care advisable when working on/in such units as they are potentially lethal even after switching them off - the smoothing/step-up capacitor(s) and the tube can remain charged to dangerous levels for minutes or more. ATB.
Afterthought: Most faulty PSUs have a simple fault when they “stop”:
You probably have done but:
Not powered up, check fuse(s) including any thermal fuses, some designers embed them in the most unusual places…
Look for any overheated items - blackened or swollen surfaces or wires will point to parts that may need to be replaced - most can be found on sale from reputable suppliers - not the Internet exchange companies’ personal sellers…
Photograph and sketch any circuits/wiring before unwiring components - polarities and orientation easily forgotten.
Common failures are diodes, triacs, secondary windings on transformers, switches and fuses, and capacitors. The biggest challenge are integrated circuits that are often unique to a product/supplier and not openly sold - obviously one could design a work-around circuit but not really worth the effort unless there is a clear (correct) functional and pin diagram(s) to steer the repairer.
Find a friendly professional electrical engineer who will have the right tools and the right knowledge and experience to repair any of the above faults for a minimal cost.
Nice constructor challenge - but the “find a comparable commercial unit - bought/scrap PC” advice is probably better. You might want to check the working PSU for in-use behaviour - such as phased start-up i.e. not all lines full power at switch on - preferably by feedback from other Retro’ers here or circuit diagram or handbooks - it is remarkable what is available on the Web about (old) products and how to fix them, failing that and with care, one can instrument the power-lines - if accessible - and you have a scope and/or voltmeters. Bear in mind that any phasing may be over in a few seconds or less so difficult to observe on simple test-equipment. Think of it as a bit like the boot-up phases on a lap-top where the boot-chip runs thro a check, then lights the screen, then runs up the disc for the OS to load; power units can include similar protective arrangements for itself or its working loads. Anyway - Good luck.
Wiser heads than mine have created this PSU: I have dissected the diagram - various parts are identifiable functions (the simpler ones…), and those occur in most PSUs. In keeping with most circuit diagrams the functionality starts on the left and generally ends on the right. This leads me to assume pins 1-3 are Line, Earth , neutral and just above is a switch for 230/115 V AC options. moving left at that level in the diagram is a standard 4 diode bridge rectification stage - plenty of chips can be used for this or 4 individual diodes (as per the diagram). The L-shaped part of circuitry above J1 is fed from Line and neutral and leads down to the out-going J1 via mains-noise filtering inductor L1.
Looking at the circuit to the RHS of the diagram, starting beyond the multiple windings transformer : The lower, 1/2 wave rectified -12V line feed straight through and to the fan. Above the Gnd line just above the -12V line is a complex block of circuitry - put simply it is a sensing circuit that monitors the input voltage (nominally 5V) and steers the A723 circuit which is voltage sensitive [protection kicks in at low/high limits. The A723 is described in great detail here:
Its function is to generate the +12V line (low current).
Last bit - the 4 transistors etc - it looks as though this monitors the overall unit as it is connected by T1 to all power lines and probably switches off the power feed Q5 T2. Obviously a full unit description may well contradict/confirm this analysis.
I can’t answer your Question about the inductor as there are good reasons to have a filter tho it wouldn’t stop the PSU functioning if omitted.
Finally - the absence of transistor/ other semiconductor product id’s, some component values, and the complexity of T1 make building a replacement PSU not a simple challenge - can providing the +/- 12V and 5V lines be achieved w/out the protective circuitry - probably Yes though it would be wise to ascertain load currents for each line from your working display,
If any Retro’rs can help Adam ( e.g. have an old spare PSU for his Tektronix display, or better details of the PSU design, I’m sure he would be grateful.), please do.
Just an update: I ended up using a MeanWell PSU and rigged up the molex connector and the CPU/interface boards all power up, LEDs flash in expected ways. Woot!
The scary bit is the feed to the CRT J1.1,2,3. If I understand @philp description, it is just filtered mains. What do the 2 4200uF capacitors (C4 and C5) do? If I dont have those, is that bad?
Hi, Adam, Congrats on resolving power supply and also your recent detailed expose on the sustained effort wrt software (elsewhere in the threads).
A general hint: In the diagram there are lots of capacitors - those with a tiny + sign are electrolytics and would have to observe a specific polarity to avoid damage - they only occur where a DC voltage is present; as you have bypassed the “build it” stage that is just a heads-up. Electrolytic capacitors are often hi-value capacitance (10-1000’s of microFarads and used for smoothing the associated DC supply.
Turning to your Q: C4 and C5 are hi-value (4700 microF) but don’t show a + sign,
they are usually quite large physically and of a paper-foil construction so not polarity - sensitive. I’m not sure why they are in the original cct except as surge or low frequency filters as they are between the L/N and Earth outputs to the display side. the neighbouring C2 R28( I think its an 8) are generally included to remove the spike when a unit is plugged in - similar values can be found in virtually all products.
It is possible (likely) that equivalent capacitors exist in you purchased commercial PSU so, as everything appeared to work OK without them - you may omit them unless - e.g. display behaviour suggests power-line noise ( as, e.g flicker on the screen, or logic misbehaviour) demands additional filtering.
General advice: A second opinion from someone more involved with PSU designs and typical display power needs would be a wise choice as I am applying knowledge gained over many years as a radar and comms engineer, and reading cct diagrams to fault-find and not as a designer. (In fact we have more in common on the software side - tho mine from the 60’s-70’s).
I don’t know the outputs from your purchased PSU nor the output to the display unit from the original Tektronix PSU.
It is imperative from a safety point of view to 1: Ascertain the actual output voltage to the display from your working Tektronix PSU - I believe it will be AC (possibly your local mains voltage) and therefore the display will include its own DC power circuitry, and 2: the bought unit would be unusual if it includes any AC output (unless it is a custom-design to replace the Tektronix PSU and has the necessary outputs).
As you managed to find the cct diagram for the Tektronix PSU is it possible to obtain a similarly detailed cct diagram for the display - whereupon even a brief examination will resolve the uncertainty. Until then just be careful.
