I got very far and even found another undocumented secret.
I have preloaded 2 sets of Festo codes into RAM in 2 loops for the syntax test (cells 103-105 and 132-133). I think I explained this long time ago. But I will make a general video soon.
Thereβs a match each on the syntax test and surprisingly the code wants to print. I patched it to print the header first. The current output is like this
**H E0 **H
/L 00006-00000 S: 0000003004
00007-00000 S: 0000003004
Originally I have this in ASCII
0052 β ββ
0052 β 'β
0110 β βHβ
0040 β β β
0105 β βEβ
0060 β β0β
0040 β β β
0052 β ββ
0052 β 'β
0110 β βHβ
0040 β β β
0015 β [CR]
0012 β [LF]
0114 β βLβ
0040 β β β
0060 β β0ββ¦
So before the header, thereβs a printout of a possible error. I have checked the ROM, and the E is always printed, followed by the error value of cell 141. E0 0 would be a keyboard error. I forgot and skipped the print of the slash.
The header is printed twice and 6 and 7 should be the start address. 3004 is the CRC which is stored at 167 and printed like the rest, digit by digit. I think this is fetched directly from the cartridge, possibly via IOT 6426.
Only missing the row of address and the codes themselves and depending on the parameter, the mnemonics. The translation into text I found long time ago. The texts are stored at 4000 (not in ASCII). I hope to find the remaining code soon.
I will probably make then a simulation including both programming device and PLC, or at least a demonstration.
