Another progress. Obviously start address at 7344 (vector at 0) and I obviously found a RAM check.
200 is maybe not the start adress (but code and reaching that sooner or later).
At a manual skip the word at 31 (1313) would be both data (index for a jump) and code at the same time what is rather unlikely.
The problem is when not having the correct start address, some values including jump addresses are different/wrong and so the (order) of the code is not as intended.
I tried again the 5162 ROM. That is more difficult, as there’s much more code before that. Some addresses are relative but I haven’t found plausible code concerning the LCD value and I would run into the empty bytes section. So I returned to the 7384 ROM.
On the cross reference list (palbart -x) there are many jumps to 6000. Starting fom that, it’s very plausible, soon jumping to 0 and later reaching 5542 (without manual skip) on where the LCD value show up and few instructions later jump to 7344.
7344 is the value at 0 (7777+1). Starting from that is what I now consider the start address.
[7344] IRQ,DLY,IE=0,1,0 L/AC:0/0000 MQ:0000 IR:4472 JMS I 0072 ;Jump to subroutine Indexed ZP 0072
[1127] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7071 CML ;Complement L
[1130] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7116 CLL ;Clear L
[1131] IRQ,DLY,IE=0,0,0 L/AC:0/1116 MQ:0000 IR:3122 DCA 0122 ;Deposit AC to memory then clear AC, ZP 0122 1116 Sixbit: IN
[1132] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1266 TAD @@66 ;Add operand to AC, Current page @@66
[1133] IRQ,DLY,IE=0,0,0 L/AC:0/5306 MQ:0000 IR:1201 TAD @@01 ;Add operand to AC, Current page @@01
[1134] IRQ,DLY,IE=0,0,0 L/AC:0/5322 MQ:0000 IR:3057 DCA 0057 ;Deposit AC to memory then clear AC, ZP 0057 +R
… soon also to 1313 like before
[1313] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:5366 JMP @@66 ;Jump Current page @@66
[1366] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:6223 CDF 2 CIF 2;KM8-E: Change to Data and Instruction Field 2
[1367] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:7325 STL CLA IAC RAL;Set L, Set AC to 0001, Rotate AC & L left
[1370] IRQ,DLY,IE=0,0,0 L/AC:0/0003 MQ:0000 IR:0132 AND 0132 ;AND operand with AC, ZP 0132
[1371] IRQ,DLY,IE=0,0,0 L/AC:0/0001 MQ:0000 IR:3101 DCA 0101 ;Deposit AC to memory then clear AC, ZP 0101 @A
[1372] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1133 TAD 0133 ;Add operand to AC, ZP 0133
[1373] IRQ,DLY,IE=0,0,0 L/AC:0/6753 MQ:0000 IR:3102 DCA 0102 ;Deposit AC to memory then clear AC, ZP 0102 6+ (OS8: Ok)
[1374] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:5750 JMP I @@50 ;Jump Indexed Current page @@50
[5330] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1373 TAD @@73 ;Add operand to AC, Current page @@73
[5331] IRQ,DLY,IE=0,0,0 L/AC:0/7332 MQ:0000 IR:3030 DCA 0030 ;Deposit AC to memory then clear AC, ZP 0030 :Z
[5332] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:1154 TAD 0154 ;Add operand to AC, ZP 0154
[5333] IRQ,DLY,IE=0,0,0 L/AC:0/2135 MQ:0000 IR:7640 SZA CLA ;Skip on AC = 0, Clear AC
[5334] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:5432 JMP I 0032 ;Jump Indexed ZP 0032
[3010] IRQ,DLY,IE=0,0,0 L/AC:0/0000 MQ:0000 IR:3164 DCA 0164 ;Deposit AC to memory then clear AC, ZP 0164
…there is soon a loop to 1313. I continue after the skip after 5334. 14 and 16 are the values for blank and underline
[5335] IRQ,DLY,IE=0,0,0 L/AC:1/4573 MQ:0000 IR:1374 TAD @@74 ;Add operand to AC, Current page @@74
[5336] IRQ,DLY,IE=0,0,0 L/AC:1/5375 MQ:0000 IR:3030 DCA 0030 ;Deposit AC to memory then clear AC, ZP 0030
[5337] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:1141 TAD 0141 ;Add operand to AC, ZP 0141
[5340] IRQ,DLY,IE=0,0,0 L/AC:1/0014 MQ:0000 IR:7640 SZA CLA ;Skip on AC = 0, Clear AC , 14=blank
[5341] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:5255 JMP @@55 ;Jump Current page @@55
[5255] IRQ,DLY,IE=0,0,0 L/AC:1/0000 MQ:0000 IR:7305 CLL CLA IAC RAL;Clear L, Set AC to 0001, Rotate AC & L left
[5256] IRQ,DLY,IE=0,0,0 L/AC:0/0002 MQ:0000 IR:6415 SRS1 ;DP8-EAEB: Read Status 1
[5257] IRQ,DLY,IE=0,0,0 L/AC:0/0002 MQ:0000 IR:6001 ION ;KK8-E: Interrupts enabled
[5260] IRQ,DLY,IE=0,0,1 L/AC:0/0002 MQ:0000 IR:1141 TAD 0141 ;Add operand to AC, ZP 0141
[5261] IRQ,DLY,IE=0,0,1 L/AC:0/0016 MQ:0000 IR:7640 SZA CLA ;Skip on AC = 0, Clear AC , 16=_
… soon reaching 20 and again 1313 with another loop. I now continue after the first skip from the recent section. Here I found the LCD value
[5342] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:1147 TAD 0147 ;Add operand to AC, ZP 0147
[5343] IRQ,DLY,IE=0,0,1 L/AC:0/1000 MQ:0000 IR:7710 SPA CLA ;Skip on AC >= 0, Clear AC
[5345] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:1150 TAD 0150 ;Add operand to AC, ZP 0150 LCD AP4 _ _ _
[5346] IRQ,DLY,IE=0,0,1 L/AC:0/7356 MQ:0000 IR:0036 AND 0036 ;AND operand with AC, ZP 0036
[5347] IRQ,DLY,IE=0,0,1 L/AC:0/3050 MQ:0000 IR:7640 SZA CLA ;Skip on AC = 0, Clear AC
[5350] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:7501 MQA ;OR MQ with AC
[5351] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:7700 SMA CLA ;Skip on AC < 0, Clear AC
[5352] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:5355 JMP @@55 ;Jump Current page @@55
[5355] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:1137 TAD 0137 ;Add operand to AC, ZP 0137
[5356] IRQ,DLY,IE=0,0,1 L/AC:0/7775 MQ:0000 IR:7650 SNA CLA ;Skip on AC <> 0, Clear AC
[5360] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:5311 JMP @@11 ;Jump Current page @@11
[5311] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:1370 TAD @@70 ;Add operand to AC, Current page @@70
[5312] IRQ,DLY,IE=0,0,1 L/AC:0/0200 MQ:0000 IR:6414 SRS2 ;DP8-EAEB: Read Status 2
[5313] IRQ,DLY,IE=0,0,1 L/AC:0/0200 MQ:0000 IR:1150 TAD 0150 ;Add operand to AC, ZP 0150
[5314] IRQ,DLY,IE=0,0,1 L/AC:0/7556 MQ:0000 IR:0366 AND @@66 ;AND operand with AC, Current page @@66
[5315] IRQ,DLY,IE=0,0,1 L/AC:0/0056 MQ:0000 IR:3150 DCA 0150 ;Deposit AC to memory then clear AC, ZP 0150 56= 00101110
…soon another loop to 1313. Continue after the first skip of that section I have a full run over
0-7777 (AC) what is probably a RAM check.
[5344] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:5361 JMP @@61 ;Jump Current page @@61
[5361] IRQ,DLY,IE=0,0,1 L/AC:0/0000 MQ:0000 IR:7001 IAC;Increment AC
[5362] IRQ,DLY,IE=0,0,1 L/AC:0/0001 MQ:0000 IR:7440 SZA ;Skip on AC = 0
[5363] IRQ,DLY,IE=0,0,1 L/AC:0/0001 MQ:0000 IR:5361 JMP @@61 ;Jump Current page @@61
[5361] IRQ,DLY,IE=0,0,1 L/AC:0/0001 MQ:0000 IR:7001 IAC;Increment AC
[5362] IRQ,DLY,IE=0,0,1 L/AC:0/0002 MQ:0000 IR:7440 SZA ;Skip on AC = 0
[5363] IRQ,DLY,IE=0,0,1 L/AC:0/0002 MQ:0000 IR:5361 JMP @@61 ;Jump Current page @@61
[5361] IRQ,DLY,IE=0,0,1 L/AC:0/0002 MQ:0000 IR:7001 IAC;Increment AC
[5362] IRQ,DLY,IE=0,0,1 L/AC:0/0003 MQ:0000 IR:7440 SZA ;Skip on AC = 0
[5363] IRQ,DLY,IE=0,0,1 L/AC:0/0003 MQ:0000 IR:5361 JMP @@61 ;Jump Current page @@61
[5361] IRQ,DLY,IE=0,0,1 L/AC:0/0003 MQ:0000 IR:7001 IAC;Increment AC
[5362] IRQ,DLY,IE=0,0,1 L/AC:0/0004 MQ:0000 IR:7440 SZA ;Skip on AC = 0
… running over to AC=7777 (>10,000 instructions) and the code skipped on AC=0, later again reaching 1313
[5361] IRQ,DLY,IE=0,0,1 L/AC:0/7777 MQ:0000 IR:7001 IAC;Increment AC
[5362] IRQ,DLY,IE=0,0,1 L/AC:1/0000 MQ:0000 IR:7440 SZA ;Skip on AC = 0
[5364] IRQ,DLY,IE=0,0,1 L/AC:1/0000 MQ:0000 IR:5311 JMP @@11 ;Jump Current page @@11
[5311] IRQ,DLY,IE=0,0,1 L/AC:1/0000 MQ:0000 IR:1370 TAD @@70 ;Add operand to AC, Current page @@70
[5312] IRQ,DLY,IE=0,0,1 L/AC:1/0200 MQ:0000 IR:6414 SRS2 ;DP8-EAEB: Read Status 2
[5313] IRQ,DLY,IE=0,0,1 L/AC:1/0200 MQ:0000 IR:1150 TAD 0150 ;Add operand to AC, ZP 0150
[5314] IRQ,DLY,IE=0,0,1 L/AC:1/0256 MQ:0000 IR:0366 AND @@66 ;AND operand with AC, Current page @@66
[5315] IRQ,DLY,IE=0,0,1 L/AC:1/0056 MQ:0000 IR:3150 DCA 0150 ;Deposit AC to memory then clear AC, ZP 0150
[5316] IRQ,DLY,IE=0,0,1 L/AC:1/0000 MQ:0000 IR:1371 TAD @@71 ;Add operand to AC, Current page @@71
[5317] IRQ,DLY,IE=0,0,1 L/AC:1/7736 MQ:0000 IR:3154 DCA 0154 ;Deposit AC to memory then clear AC, ZP 0154
