Hi everyone,
My name is Alex. I’d describe myself as moderately clueless but highly persistent, and I am currently stuck on a hardware project for my Ericsson MC218 (mainboard revision 2.0).
My goal:
I want to upgrade the device from 16MB to 32MB RAM, ideally getting it recognized under the stock Ericsson EPOC system first, with the long-term option of booting PsiLinux/ or the 5MX Pro EPOC from a CompactFlash card.
My setup:
I have proper test/measurement equipment (oscilloscope, multimeter) and the correct, matching 8MB RAM ICs (K4E641612E-TC60).
I successfully populated all four RAM footprints (4x 8MB). The device boots fine into the original OS, but stays at 16MB.
I built a discrete DTL NAND gate (diodes/transistor) on the empty IC20 footprint near the MROM area to simulate the bank-switching logic. The machine boots up normally into 16MB, confirming the discrete logic works in idle, but doesn’t trigger the extra banks.
I am struggling to understand the exact memory map and banking routing for the different board revisions and RAM options based on the available V3.00 schematic hosted by @variable1471, which can be found here:
For instance, on my Rev 2.0 board, the two 5-pin gate footprints (TC7SH00F and TC7SH02F) near the RAM chips are unpopulated, which matches some photos of 32MB Pro boards I’ve seen, but there is an empty 3-pin SOT-23 footprint near the RS-232 port that might act as an alternative inverter or power-switch for the extra CAS/RAS lines? I can’t wrap my head around how Bank 3 and 4 are structurally selected on this specific revision.
If anyone here - maybe @variable1471 - has done the 32MB mod on a Revision 2.0 board or understands the exact signal traces for the non-Pro vs. Pro hardware layouts, I would highly appreciate your guidance! I can
provide high-resolution macro photos of my PCB if needed.
Thanks in advance,
Alex
