Correcting errors by duplicating processors
I saw a question in another Internet forum earlier that reminded me of a very interesting (to me) piece of computing history. The original Apollo workstation ran on a Motorola 68000 processor, which had a design flaw that prevented page fault instructions from being properly interruptable and restartable, making “safe” memory management with non-error page faults difficult. A proposed fix from Motorola was to install a second 68000 processor just to handle page faults and correct this error, so that the primary processor’s bus cycle can be restarted (after signaling a bus error). I had heard of this trick a number of times over the years (although it was sometimes characterized as being used in the Sun 1, which also used the MC68k processor; perhaps it also used this technique, I don’t know, but it used a custom MMU so perhaps it was not necessary), but never chased it down and confirmed it as not-an-urban-legend.
It turns out that it is definitively not! Motorola issued a document, Design Concept DC-001: Virtual Memory Using the MC68000 and the MC68451 MMU, that describes the workaround that I believe was implemented on the Apollo, which is available for examination.
https://ia802609.us.archive.org/34/items/Motorola-SeminarsandApplicationBooksDC-001VirtualMemoryUsingTheMC68000AndTheMC68451MMU/Motorola-SeminarsandApplicationBooksDC-001VirtualMemoryUsingTheMC68000AndTheMC68451MMU_text.pdf
The first proposal outlined in the documentation is described as “relatively conservative of hardware”, which seems like a surprising characterization to me, given that it involves installing a second state-of-the art and quite expensive CPU! A block diagram for this “bus rerun” architecture is presented, with the caveat that read-modify-write instructions like test-and-set cannot be restarted, and so user software that may invoke this page fault mechanism cannot use such instructions.
Note that both the blocks labeled “Executor” and “Fixer” are 68000 microprocessors in this diagram, while the block labeled “MMU” is a 68451.
The application note goes on to describe a “bus cycle suspension” method that, instead of restarting the bus cycle after correcting the fault, inserts wait states on the primary CPU while the fault is corrected, allowing it to continue (rather than restart) its interrupted bus cycle. This method, while superior to the “bus rerun” method in that it has no limitations on what instructions can be subject to page faults and still complete successfully, is said to have the disadvantage of “the amount of hardware required”. Nonetheless, the note (correctly, in my opinion) asserts that this method is “preferred as it results in a more powerful and versatile system.”
The document goes on to provide a full schematic for the suspended bus cycle method, as well as various timing diagrams and functional descriptions to help an implementer make this dream (nightmare?) a reality.
I do not know which method the Apollo workstation in question used, but I suspect it was the second – documentation can probably found to confirm this, but I have not personally checked. As Wikipedia notes, the Motorola 68010 fixed this deficiency, and did not require the workaround.
I think I’ve read that Sun and Apollo took two different approaches, and that seems to be confirmed - Wikipedia says Apollo used the dual 68000 approach, and this post from Marcus Watts to the FreeBSD list says Sun built their own clever scheme:
The sun-1 did not have a dual CPU page fault arrangement. It used a slightly higher clock speed version of the same CPU board used previously used by codata & 4 other vendors, originally designed by stanford university. Instead of using the motorola MMU which was late to market, expensive, & slow, or industry standard MMU cache logic (“TLB”), they used a very clever generic chip implementation that used the CPU alternate space instructions to manage dedicated high speed RAM which provided all the mapping. This managed a page addressed space, but did NOT do demand paging. Another exciting low-cost feature of the sun-1 CPU was “software” dynamic ram refresh - every 2 ms, the CPU was interrupted by the refresh interrupt and would execute 127 nop instructions. The sun-2 was very similiar to the sun-1, but upgraded the 68000 to a 68010 (which could do instruction restarts and hence demand paging), deleted the onboard RAM, and instead added the ability to use DMA via an IOMMU to private bus RAM. The sun-1 ran unisoft version 7 unix, complete with swapping. The sun-2 ran “4.2bsd”.
This approach has quite a history. The UNIVAC I had most of its major processing components in duplicates and connected to two separate buses. The machine would monitor the two parallel subsystems and halt on any discrepancies for the operator to decide, whether to resume or to change to the other bus. (However, this was not because of any faults in the memory access performed by these buses, but rather due to faulty vacuum tubes and possible failure in the processor itself.)
