Connect to a PDP-8/e running TSS/8.24
(You might not be able to connect, because the machine has just 6 serial lines and it’s surely going to be very popular for a day or so…)
 * Authorized users only - All activity is monitored.
 * To request access visit https://livingcomputers.org
 * Use ssh tss8@tty.livingcomputers.org to connect.
 * Guest access is available:
 * LOGIN 1000 LCML
 * LOGOUT
 * CTRL-] quit to return to the menu
TSS/8.24 running on a PDP-8/e!
You are invited to play on a REAL PDP-8/e running the TSS/8 monitor (TimeSharing System 8) pictured here. There is a user contributed tutorial here:
https://wiki.livingcomputers.org/doku.php?id=tss_8
To connect, ssh tss8@tty.livingcomputers.org
If you are unable to connect that means all 6 (yes, just 6) lines are in use. Remember, this is real hardware and there is NO EMULATION happening. It is the real deal! Enjoy!
via mastodon
This may be an interesting test regarding grown up abilities of retro computerists. (I wonder, how many will try to bring the system down. Statistics may be interesting.)
I tried this and text wouldn’t echo, and the login command they gave did not work (assuming that it was actually taking the characters, and simply not echoing them).
All I got was LOGIN PLEASE repeatedly for my efforts.
I just tried again and it worked for me. Indeed you have to blind type the login command to the . prompt (I tried pasting and I think that didn’t work)
LOGIN 1000 LCML
Time passes…
CRASH !!!!!!!!!!!!!!!!
YOUR IMPACT CREATED A CRATER 870.9618 FEET DEEP.
AT CONTACT YOU WERE TRAVELING 3088.711 N.MILE/HR
Just don’t try that on REAL hardware. What baud rates can you get?
BTW, I did get bumped off somehow and when I got back in, I was already logged in. So just possibly that was the situation you were in.
Not sure about baud rate but it takes nearly 20 seconds to list the files with
R CAT
