@MauryMarkowitz OK, I had the AI review the code and write regression tests. Here is its summary after it wrote the regression tests. Pull request. Review details.
Regression Test Results
Date: 2026-04-12
Platform: macOS, Apple Clang/GCC
Branch: claude-review
How to Run
cd Review
make # build C tests
./run_tests.sh # run all tests
make asan # rebuild with AddressSanitizer (recommended for C1, C3, C5)
Results
| Test | Type | Result | Confirms Bug? |
| C1 - Negative array subscript | FOCAL | WARN (UB didn’t crash) | Yes - code uses negative C array index |
C2 - str_new(NULL) |
C (fork) | FAIL - SIGSEGV | Yes |
C3 - str_new overflow |
C (fork) | FAIL - 400 chars in 257-byte buffer | Yes |
C4 - str_erase inverted |
C | FAIL - all 4 cases wrong | Yes |
C5 - str_append overflow |
C | FAIL - 400 chars in 257-byte buffer | Yes |
C6 - lst_insert_at_index |
C | FAIL - self-ref + infinite loop | Yes |
| C7 - FIN fall-through | C | FAIL - returns random, not 193 | Yes |
| C8 - Wrong struct member | C | FAIL - .number still 12345.7 |
Yes |
C9 - lst_node_with_key NULL |
C | FAIL - returns wrong node | Yes |
C10 - lst_copy broken |
C | FAIL - data is heap pointers | Yes |
| C11 - Comment text lost | FOCAL | FAIL - text not in WRITE | Yes |
All 11 critical issues from review.md are confirmed.
Test Descriptions
FOCAL Tests
C1 - test_C1_negative_array_subscript.fc
Sets and reads A(-1) and A(-2048). FOCAL allows subscripts from -2048 to
+2047, but the C array backing storage starts at index 0. Negative subscripts
index before the allocation (heap underflow). On this platform the undefined
behavior did not manifest as a crash, but the bug is confirmed by code
inspection and would be caught by AddressSanitizer.
C11 - test_C11_comment_text_lost.fc
Stores a COMMENT with text, then uses WRITE to list the program. The lexer
computes yyleng - strlen(yytext) which is always 0, so all comment text is
discarded. WRITE output shows COMMENT with no text after it.
C Tests
C2 - test_C2_str_new_null.c
Calls str_new(NULL) in a forked child. The function calls strlen(string)
with no NULL guard, causing SIGSEGV.
C3 - test_C3_str_new_overflow.c
Calls str_new() with a 400-character string. The function allocates 257
bytes (MAXSTRING+1) and uses strcpy with no bounds check. The child
process detects the overflow (or crashes from heap corruption).
C4 - test_C4_str_erase_inverted.c
Calls str_erase("ABCDEFG", 2, 3). Expected result is "ABFG" (middle
removed). Actual result is "CDE" (only the deleted range is kept). Tests
four different cases; all four produce inverted results.
C5 - test_C5_str_append_overflow.c
Appends 200 characters onto a 200-character string in a 257-byte buffer.
str_append is just strcat with no bounds check. The resulting 400-character
string confirms the overflow.
C6 - test_C6_lst_insert_at_index.c
Inserts into a list at index 1. Line 334 of list.c sets
new_node->prev = new_node instead of tmp_node->prev = new_node. The test
detects the self-referencing prev pointer and the resulting infinite loop in
backward traversal.
C7 - test_C7_fin_fallthrough.c
Reproduces the switch/case structure from evaluate_expression. The arity-0
FIN case reads a character but has no break, so it falls through to FRAN
which overwrites the result with a random number. The test calls FIN and checks
whether it returns 193 (correct) or a random value (buggy).
C8 - test_C8_wrong_union_member.c
Reproduces the value_t struct layout. In the numeric branch, when the
variable lookup returns NULL, the code sets result.string = 0 instead of
result.number = 0. Since these are separate struct fields at different
offsets (8 vs 16), .number retains its stale value.
C9 - test_C9_lst_key_null.c
Builds a list where the middle node has a NULL key. Searches for a key that
exists on the third node. The search loop exits early when it hits the NULL
key and returns the wrong node (data=200 instead of data=300).
C10 - test_C10_lst_copy_broken.c
Copies a three-element list [10, 20, 30]. The copy’s second and third
elements contain heap pointers (the list_t node structs) instead of the
original integer data, because lst_append(new_list, new_node) stores the
node struct as data rather than new_node->data.
Files
Review/
review.md # full code review
test_results.md # this file
Makefile # builds C tests
run_tests.sh # runs all tests
test_C1_negative_array_subscript.fc # FOCAL
test_C11_comment_text_lost.fc # FOCAL
test_C2_str_new_null.c # C
test_C3_str_new_overflow.c # C
test_C4_str_erase_inverted.c # C
test_C5_str_append_overflow.c # C
test_C6_lst_insert_at_index.c # C
test_C7_fin_fallthrough.c # C
test_C8_wrong_union_member.c # C
test_C9_lst_key_null.c # C
test_C10_lst_copy_broken.c # C
