Going back to your original post - for many reasons…
I am a big fan of adventure games - being brought up on the original Colossal Cave, then Zork, Infocom, some of the Scott Adams ones then MUDs. I even wrote my own MUD which ran online for the best part of 20 years. I could write several books on that one…
Some thoughts out-loud - maybe critical but not intending to criticise… Writing adventures and creator systems is something close to my heart too - sadly now I lack the time to take it much further - for now, anyway…
So the aim is to write some sort of adventure game creator and execution system - but you wanted tape?
I’m going to suggest that that’s not feasible or practical today. The Infocom ones needed a back-end disk paging system just to deal with the rich textual environment, so without that, you end up with tiny adventures with a minimal wordset or you start to use a compression techniques which adds to the code complexity.
People do still use tapes on old systems though - but almost all I’ve seen are really PCs with sound card outputs and the tapes being digitised and stored as files on the PC. Old computers have a multitude of disk emulators now too - from the “flux” level to complete re-implementations using modern parts. I suspect very few people use actual floppy disks now.
Could you bootstrap it off tape by loading the core interpreter, then the word-list, then the map/database and room descriptions? What about custom code triggered by actions…
Then… Basic or a basic-like language. Because you want others to write their own adventures or because you find it easy to write in Basic yourself… Maybe that’s a limitation?
Writing/developing on the target or an external system? Todays programmers are often brought up on using an IDE running on their desktop - to produce code for different targets, but back in the day - An exception might be Infocom though - they used a PDP-10 (at least initially) to do the development then they had a target execution environment for every system. Not sure about the Scott Adams one but it looks like he did something similar - a common game file then custom machine run-times.
Wind on a year or 2 and people were writing in Basic in their home PCs - not always fast but it worked.
Round about the early 90s MUDs started to gain popularity due to this new-fangled thing called “The Internet”. Mostly still text based when the PC ones were moving to graphics. These were mostly written in C, running on “borrowed” work or university systems like Sun workstations and other (typically) Unix systems. Mine first saw the light of the 'net in late 1992…
Where does that leave us today?
I’d love to port my MUD engine to a retro system - but it’s written in C (the engine) and the actual “world definition” is written in a intermediate language - a C-like thing which handles lists and database objects natively. The world is a database which holds text or code or lists of database objects. The code is compiled into a bytecode.
Then there is the parser - if verbs and nouns were good enough for Colossal Cave then …
Kill Dragon
What with, your bare hands?
Yes.
Amazing.
How deep do you want to go? That can become very complex very quickly. For the most part, I stuck to the old verb/noun thing, but it could parse stuff like
unlock door with skeleton key
but it was fairly brute-forced - the parser looked for the keyword “with” then returned a left side and a right side. The left side was searched in the room contents and the right side searched in the players inventory… Not the best, but very workable and if it all matched then a function bound to the left side was called. It was good enough.
Returning from that rabbit-hole…
Could this be done on an 8-bit micro? Sure. Infocom did it - separate dev. environment, per-system run-time.
The hard part is writing the per-system run-time.
But lets say we target systems that already have Basic (maybe this is the intention?) Back in the day the magazines published big (and they got very big) posters detailing the difference between Basic dialects on different systems - most systems that run a Microsoft Basic were very similar - Pet, Apple II, TRS-80, Various CP/M systems, OSI/UK101 and so on. The changes were minimal. Other systems with their own Basics were more troublesome - ZX Spectrum, BBC Micro and so on. String handling was often an issue too.
Memory sizes too. The Beeb was criticised for only having 32K of RAM at the time when the Apple II had 64K, the Spectrum 48K and so on, however you can run Zork on a Beeb…
So - you create a common language/descriptor system then write the world generator and a set of run-time subroutines for every different Basic platform then have the generator crank out optimised code for each platform and “link” in (ie concatenate) the “library” for each platform and off you go.
If only life were that simple…
I’d like to do it again, but the target - it would be easy to target modern MS Windows or Mac, or Linux - but the old/retro systems running 8-bit Basics? I’d probably write a run-time to interpret the game world/database, etc. but how many different systems, how long have I got?
Plan B: Make your own little 8-bit SBC with the sole intention of running a text-based adventure game - VGA graphics, USB keyboard enough RAM - open source or sell it… Uptake… Single digits.
Have you seen Pico-8?
I’ve waffled too long…
