I am curious if anyone can list some sources that really explain how to do standard 40-bit FP on a 6502. I’m aware of some sources from the 1970s, but have not come across anything really in-depth.
For instance, I’ve seen Woz’s code from Dr. Dobbs in 1976, but it is almost completely undocumented. A number of similar code-pulls from things like Commodore BASIC or Atari BASIC are easy to find, but they only explain the code, not the underlying theory.
There are some recent web pages that talk about different aspects, like Calc65, but this is really an application as opposed to an explanation and assumes you understand all the basics.
Finally, there are some in-depth sources, mostly books from the late 1970s. But I have been told they generally do not closely match real-world implementations, as there were issues with them that “everyone knew” but are never explained.
So does anyone know of a really good resource for this? One that starts with the basics but also has comparisons of various approaches and their trade-offs? One that explains, for instance, how the MS FP system works and then explains alternatives/problems/tradeoffs/improvements?
Are we talking decimal or binary floating point. 32 bits is binary. 40 bits BCD in general.
I am looking for the same thing as well, mostly how to handle floating point I/O.
I mostly understand how it works - at least the IEEE754 style of 4-byte floats. However I have not yet written any actual (6502) code for it - mostly because I had another platform for my 6502 system that could do it faster (a floating point co-processor if you like)
The principle is thus: A floating point number has 3 parts.
The sign - that’s easy, one bit.
The exponent - a number of bits (8 in single precision) which is a power 2^exponent (this is biased to take into account the sign of the exponent - negative is a fraction
The fractional part or mantissa. (say 23 bits in single precision)
So that’s 32 bits. Just make sure you assemble them in the correct order.
If you can cope with “scientific notation” where 1234 might be represented as 1.234 x 10^3 then you are on your way. (or 0.001234 might be 1.234 * 10^-3 … there’s a negative exponent but a positive number) You just have to do it in binary.
Look out for “normalisation”. That’s a trick to maximise precision which involves shifting the mantissa up and adjusting the exponent to maximise the number of significant digits. So if you have 0.001234 you might actually want to store that as 1.234 (with adjusted exponent) to give you more space for more significant digits so your next calculation with that number has more digits to play with.
And part of the issue “back then” was that there were no real standards. A few looked promising and IEEE 754 emerged. (Neither Woz nor MS are IEEE754, but they work using the same principle of sign/exponent/mantissa)
Interesting question, but everything hinges on what you already know and what level of description you’re looking for. There was an article in a 1977 BYTE which might be helpful: What’s in a Floating Point Package? (Sheldon Linker, BYTE, 1977-05, Vol 02 Number 05)
There’s quite a nice explanation at The Floating-Point Guide - Floating Point Numbers
but most of all a couple of handy links at the bottom of the page. In particular, Float Toy lets you flip bits to see how a number changes, or type a number in to see which bits represent it.
I think the floating point formats we normally see in the 8 bit world are very like the 32 bit IEEE format, it’s just that they only bother with ordinarily representable numbers from the small to the large. (They don’t do infinities or not-a-number or the unreasonably small denormalised numbers.)
So, if you understand standard single precision floating points, you’ve got the basics. Actually doing the necessary shifting and comparing and operating byte by byte is the usual thing in 8 bit land - I don’t think anything very unexpected is happening.
Perhaps the only thing to look out for is that the working space for floating point routines will usually have an extra byte of precision, to be rounded off and improve accuracy. Oh, there’s often an implicit 1 bit at the MSB of the mantissa, to save a bit.
Oh, but hang on, it looks like the fields in IEEE format at not byte-aligned, so most likely in an 8 bit floating point format the bit allocations will be slightly different. For example, this explanation of Acorn’s BBC Basic for the 6502 shows that the 8 bits for the exponent come first, the sign bit is next, then the 31 bits of the mantissa (with the sign bit sitting in the same place as the implicit 1.)
Both MS and Acorn used binary arithmetic - BCD isn’t a great performance option on the 6502, addition and subtraction being supported well but multiplication and division coming out more difficult than in binary.
Okay, now I have a vague memory of some microcomputer … I think it used 6502 … where the floating point math was based on base 256 instead of base 2. The 6502 only had commands to roll left or right one bit at a time … not the most efficient thing ever, if you’re fiddling with carries for multi-byte mantissas.
So the idea was for the exponent to represent byte shift rather than bit shift. Shifting by 8 bits at a time was quick and efficient, and incidentally easier to code.
I want to say it was one of the UK micro computers that did this. I don’t remember, but in any case I really like the concept.
They had a few advantages - namely the 65C02 vs the 6502 that those Basics are written in (although the version of EhBASIC has been slightly optimised for the 65C02 and it’s an on-going process). Also the older BASICs on the BBC Micro were still considerably faster, all things considered. (About 62 seconds)
I haven’t found an example, but I think this would be called radix 256. The problem with it is that when aligning values you might lose 7 bits off the end, so you lose precision. So you need extra precision to make up for that. I did find this note on a big page of floating point formats:
The TI 99/4A uses radix 100 in an 8-byte storage format. 7 bytes are base-100 mantissa “digits” (equivalent to 14 decimal digits), and the exponent (a value from -64 to 63) is stored in the 8th byte along with a sign bit. The exponent is treated as a power of 100.
Well, you lose an average of 3.5 bits of mantissa, but you gain 3 bits of exponent. Okay, I don’t think you can legitimately “average” the lost bits of mantissa, but still …
I guess if it actually existed and wasn’t just some random discussion of floating point ideas, it must have been somewhat obscure.
No reason for us to not implement it anyway, though, right? I’d go with 1 byte signed exponent (really overkill), and 7 bytes signed mantissa, zero allowed. There’s no implicit leading 1 because that only makes sense for a binary mantissa. The various math operations seem pretty straightforward to me. The only clever bit would be altering exponent at the end of add/subtract operations. You want to check for either leading $00 or leading $FF, rather than just leading zero bits.
I think it might well be that aligning before add and subtract, and normalising afterwards, are fairly costly, so it might be worth a go! With 7 bytes of mantissa it feels like you’ve plenty of margin. (It’s 2.4 decimal digits which might be lost, although as you say, on average it’s half that. One might consider doing what calculators do, and rounding at the conclusion of a complex expression. You’d quite like the square root of a square to be an integer.)
I can’t be sure if @IsaacKuo’s base 256 idea is totally original, but I’m intrigued by the performance aspect of it. Six bytes should be plenty for native precision, so if the performance boost is worth the size penalty, I see no reason not to spend some time test-coding. Oh, wait … time … sheesh.
I think maybe my vague memory is from a USENET discussion where someone described the TI 99/4A as base-256. Or I read it wrong. Or I remember it wrong.
RADIX-100 has some interesting advantages. The big one would be how financial numbers worked (here in the USA, at least). You could calculate with a cent being 0.01 and various important sub-cent values … and they would be accurate. On other computers, you’d have to know to use integer values and pretend there’s a “.” before the last two digits. And hope to heck you don’t have any places where 1 means 1 dollar. And if you had to do some financial calculations that involve sub-cent values then you were … uhh … well, good luck!
For a general purpose home computer, where you couldn’t expect users to be familiar with the limitations of (binary) floating point math? I can see how the TI 99/4A route would make more sense. Especially for Texas Instruments, considering their most popular products were calculators that did precise decimal floating point math. Those calculators never surprised users with a “gotcha!” while doing basic financial calculations.
It’s very good point: people have expectations about how numbers work, and calculators (usually) play to those expectations, and TI might well have wanted to avoid being confusingly inconsistent.
